I recently acquired an Allen Scythe, 2 stroke 25c engine I think, that has not been started for years. Cleaned the carb, and tank, replaced the points, Plug, Condenser and coil, gapped the points and reset the timing after cleaning everything. Finally got it started on first pull, twice, then it stopped. Did not have the flywheel bolt tight enough…re- timed…fixed. Engine ran sweet up till this point, no issues. However, found that there is very little difference between points open and points closed to a point where, if they are gapped at 15 thou, they don’t fully close. Put a meter across them to find that I had to close them down to about 10 thou to get a points closed reading on the meter. Any one had this problem before and found a solution ? Almost sounds like the eccentricity on the points cam is worn down. Could it be anything to do with the governor ?
Also, the magnets were intermittently fouling the coil carrier brackets very slightly scraping, so repositioned coil and backplate as far as the screws would allow, seems OK now. If anyone can assist with this, it would be very much appreciated as I am not getting a spark now at-all.
Hope this all makes sense ?
