Home › Forums › General › Help and information › Villiers F15 stationary engine
- This topic has 45 replies, 6 voices, and was last updated 5 years, 7 months ago by
November 11, 2020 at 5:42 pm #35765
vhgmcbuddyKeymasterGood evening. New on the forum and specifically looking for technical info regarding Villiers F15 stationary engine. I just bought one of these for 20 quids at a scrap metal depot here in Holland. The engine seemed to be in relatively good shape and was complete.
I started pulling it apart to check it’s condition. It does seem to have been over used and have already checked the valves/piston. It does not have spark and brought it to my favorite mechanic to remove the flywheel and one of the muffler’s bolts (do not have imperial tools so do not want to risk damaging anything). Need to have access to the points/coil as it seems there is no condenser and the points are not opening much and neither at the right moment.
What is the timing on this engine? is it 3/16″ before TDC?
Also, what year (s) were the F15 being manufactured?
Thanks for your help
JeffNovember 11, 2020 at 6:18 pm #35770andyfrost
ParticipantIt sounds like you have the wipac ignition that has the coil/condenser in one single unit , hence you can’t see the actual condenser.
The timing is fixed by a keyway , so no issues there.Andy.
November 12, 2020 at 8:22 pm #35782
vhgmcbuddyKeymasterDear Andy. Thanks for your quick reply. Hope to have the engine back with the flying well off on Saturday. Shall look further into the ignition i.e testing the coils, condenser and adjusting the points. Yes it is a wipac ignition. Already ordered new condenser and points (from the UK) so may replace if necessary.
How/where should the spring on the governor lever be connected? The spring was there on the lever but no connected to anything?
The tap on the tank is made of cork: how can I replace it as it is very lose and I don’t think it closes really.Warm regards
November 12, 2020 at 9:11 pm #35783andyfrost
ParticipantAs regards to your govenor spring , it depends on whether it was fixed revs or variable , either way you should have a bracket on the valve chest cover , have a look and report back what you have there , if anything.
Remember your ignition unit is a combined coil and condenser, fit your new points and you’ll more than likely have a spark , they’re normally a very good unit and seldom give trouble.Andy.
November 12, 2020 at 9:15 pm #35784
ssorthiekParticipantI’m no expert on anything really but I have had quite a bit of success getting a few WICO series A and WIPAC series C magnetos going without the need for new points and if you are just trying to get the engine running, you might get away without the condenser to prove the engine is a good one. The condenser really needs to be in place when you are satisfied that the engine is good otherwise you may well damage the points.
I think what you have got is a WIPAC series C magneto (possibly) and you will probably need a special tool to take the condenser out. I made one and it works really well but you do need a lathe and a mill to make it properly. I can probably take a photo of the tool if this helps.
Andy is far more experienced than I and he (and others) may well correct me and I would be interested in any differing views.
November 12, 2020 at 9:18 pm #35785
ssorthiekParticipantJeff
Following Andys previous post, it might well be worth adding a couple of photosNovember 13, 2020 at 8:32 am #35787
vhgmcbuddyKeymasterDear Andy and Ssorthiek. Thanks again for your support. Really appreciated. Just called the mechanic: flywheel is off. Will pick it up tomorrow and sure will share some pictures.
The bracket on the valve chest cover is there, but what I am wondering is if there is anything between this bracket and the spring, something to adjust the load of the spring as I have seen on some videos on youtube.
JeffNovember 13, 2020 at 2:36 pm #35788andyfrost
Participant“something to adjust the load of the spring”
That is precisely how it works , a threaded adjuster for fixed revs , or the end of the cable for variable.
Keith , we’re talking flywheel magneto here , not a CJ or A series which are of course seperate mags.
Andy
November 13, 2020 at 7:54 pm #35789
vhgmcbuddyKeymasterNovember 13, 2020 at 7:55 pm #35791
vhgmcbuddyKeymasterNovember 13, 2020 at 8:21 pm #35793andyfrost
ParticipantDepends whether you want to do an accurate restoration , or just get it running , it would be a simple task to make an adjuster from a suitable threaded bolt, drill a hole to accept the spring and just use a nut either side of the bracket for adjustment.
Meetens would more than likely have the proper part , but proper money to go with it.Andy.
November 13, 2020 at 8:33 pm #35794
vhgmcbuddyKeymasterNovember 13, 2020 at 11:11 pm #35797
wristpinParticipantNovember 14, 2020 at 8:45 am #35804andyfrost
ParticipantCheers Angus , as the song goes …….. a picture paints a thousand words.
November 14, 2020 at 7:28 pm #35810
vhgmcbuddyKeymasterDear Angus
Thanks for the pictures indeed. I can copy the adjuster.
Here is a picture of the coil + points.
What should be the opening of the points? I set them at 14 thou (0.35 mm)?
What should I expect when testing the coil? I got 3440 ohms
(3.44 with meter set on 20 k)
Should received the spares I ordered within days: looking forward to get it all back together and see if it starts.
Cheers Jeff -
