Uni Horse Tractor
Home › Forums › The Main Forum Area › Projects › Uni Horse Tractor
  • #35454
    chrisr
    I am just about to start a renovation of a Uni Horse tractor BSA engine c1967 – is there anyone out with a similar experience / tips etc. Thanks Chris
    #35512
    ssorthiek
    Is this your first attempt at restoration or are you an old hand at restoring old equipment?
    #35536
    chrisr
    first time really for a restoration, although i have some mechanical knowledge
    #35537
    ssorthiek
    Restoration is relatively new to me as well. You will see the results of my Coleby restoration below.
    There a a couple of bits of advice I can give. Take plenty of photos is one of the most important things you can do before, during and after disassembly. I’ll be doing quite a bit of that tonight on my new project. The other thing is, when you take something apart, make sure you understand how it works and try and work out why it was designed a particular way. If you do this, when you reassemble you will understand how it works and have more chance of getting it together first time.
    Keep your working area reasonably tidy. I’m not sure what your set up is, but I started off with a make shift bench with a very cheap and chearful drill vice, a dark badly lit garage, a bench pillar drill on the floor and so forth, none of which is conducive to a good restoration project. I have now a decent bench, good lighting, a small bench vice and quite a bit of other equipment, lathe, mill and so forth, much more comfortable and easier to work.
    You will work out your own methods for releasing seized nuts and bots, but plenty of WD40, PlusGas normally suffices, with a good heat gun for the more difficult to remove fixings.
    The other thing you have got to consider is why you are doing this restoration in the first place. I had and have an number of goals, most are family oriented. My intention is to show three working Colebys at some shows next year, I currently have two. You may be able to do quite a bit of research into the UniHorse on the internet, but make sure you print everything that you find and put it in a file. This will help with the interest over the winter months when it is particularly cold, should help the the restoration and will probably be of interest to a potential buyer if and when it is time to sell.
    Painting. I’m not sure what finish you are after, but if you are thinking of hand painting, use a good quality enamel paint (try Paragon Paints). Normal metal paint is not good if it comes into contact with petrol (I can say this from bitter experience). If you intend to powder coat, try to get everything done at the same time.
    Most importantly of all, enjoy.
    Not sure that any of this is any good to you but hopefully there will be a few bits and pieces in there to help you on your way.
    #35560
    chrisr
    thanks very helpful, Chris
    #35561
    ssorthiek
    Another bit of advice I would give is coat every thread with some copper grease. This will make taking the thing apart much easier if you need to and believe me you will need to if this is your first attempt. You do need to be mindful that you will be able to exert much more force on the bolt or studs when compared to tightening a dry thread and it will be much easier to over tighten them. Just use common sense in this regard and you should be OK.
    Stud lock is very useful and will normally hold studs in place easily so long as the threads are clean.
