Trusty skimmer
  • This topic has 4 replies, 2 voices, and was last updated 1 year ago by will.
  • #42252
    will
    Hi all,
    I’m looking for a skimmer for the disc coulter of a Trusty tractor plough. Are they available?
    If not am I allowed to use (I refer mainly to ploughing matches) a skimmer from something else, such as Ransomes or Kverneland?
    Thank you,
    Will
    #42261
    They aren’t available I’m afraid. Most people adapt another make of skimmer to suit the Trusty disc to get over the problem, but don’t stop looking for a genuine one, they do come up occasionally but you will normally have to buy a whole plough to get the skimmer.
    #42263
    will
    Thanks Geoff, if I did that would I be able to compete at ploughing matches? I only ask the question as I thought I had read somewhere that – essentially – everything on the plough had to be original, or from the correct time period or something.
    Thanks!
    Will
    #42269
    That’s normally the case but when the original is so rare there has to be a certain amount of discretion used. So long as it looks and works in a similar way to the original nobody will pick you up on it.
    #42275
    will
    Perfect Geoff, thanks again 🙂
