Hello Robert.
When I had a chainsaw tarpen flex attachment it was fitted with the shaft which had the twistgrip clutch at the end, most useful if you got the saw jammed or needed to stop the blade in emergency. I would not entertain using the saw attachment without that little clutch unit.
Chris
