Suffolk cast iron block gaskets.
Home Forums The Main Forum Area Projects Suffolk cast iron block gaskets.
  • #8766
    Does anyone know if any firm is producing gaskets for the old cast iron block engines? In particular the one between the block and sump. And before anyone tells me, I know that I can cut one out from gasket material but I have several to do and a / I’m lazy and b/ they use up a lot of gasket material when there’s no call for small ones to use up the middle bit!
    #8769
    hillsider
    These companies may be able to help with a small order but I bet it comes at a cost!
    I have used Sampson Challis back in the days when they were JW Challis for the supply of gasket materials but you would need to check to see if they can still make small quantities of cut gaskets.
    https://www.sampsonchallis.com
    https://www.classicenginesandspares.co.uk/gaskets.html
    https://www.stephensgaskets.co.uk/index.php
    Good luck.
