Simar spares?
  • #7632
    Don’t know if anyone can help, one of the handles on my 35c decided to snap while doing my veg patch, I have tried welding it but it won’t hold, where could I get a replacement?
    #7636
    jtg1
    the usual way to repair tubular handles like that, depending where the break is is to insert a heavy section tube inside the original for some length either side of the break. drill the original handle with half a dozen holes either side of the break so you can plug weld through to the inner suporting tube, then simply weld round the break in the tube and tidy up with a flep wheel on a grinder. very strong and hopefully invisible with a drop of paint. 35c handles are renound for rotting, so finding replacements will be difficult
    #7643
    I had to do a similar repair to the handles on my 35c. If you can post a photo of the broken handlebar we may be able to offer further suggestions. The 35c does not seem to be as common as the bigger 56a.
