Repair Wolsley Webb Centaur
Home › Forums › General › Help and information › Repair Wolsley Webb Centaur
  • #37953
    david-powers
    Dear Sirs,
    I have a Wolsley Webb Centaur Tiller and all the parts to go with it. I have used it well but it appears that there is a loss of power when tilling then cuts out. I have taken it to a Lawn mower repair In Llangrove near where I live he suspects it is the bore or crank that has worn. Do you know if this could be repaired i.e. rebore and new piston rings and repair the crank.
    I’m sorry to trouble you but it seems a shame to just through it away, I bought it second hand but it has proved its use and i would like to use again. Any assistance would be gratefully recieved.
    Best Regards,
    David Powers
    Tel 01989770426
    #37954
    Remove the cylinder head first and check the bore for any undue scoring , if it seems OK , then replacement rings are available. If oil starvation has damaged the bore , I would opt for a replacement engine , good used ones regularly turn up on the well known auction site..
    Depending on how much you’re prepared to spend ,brand new Honda copies are available which will fit straight on.
    “Suspects” worries me. At the best an educated?guess. As AF has suggested, lift the head and inspect the bore for obvious deep scoring or galling. If all appears to be well, there’s not much more to be discovered without serious dismantling and measuring. You don’t mention the make of engine fitted but if it’s a side valve Briggs and Stratton I’d have a look at the valves. A valve job / top end overhaul can be done without special tools but a couple do make life easier.
    Take the valve chest cover off and before going any further check the valve gaps. Most BS side valve lumps need 5-7thou on the inlet and 7-11 on the exhaust for early ones and 7-9 on the later. Measured with the piston 1/4” down from Top Dead Centre on the power stroke. If the clearances are tight it’s an immediate pointer to go further and remove the valves. Inspect the valve faces and seats and also for any signs of a loose seat. Particularly a loose seat as they can come adrift when the engine warms up but sneakily drop back into place as it cools.
    No point in me going any further until those “suspects” have been checked.
    If you don’t feel up to doing this, either find a slightly more enthusiastic engine man or, as AF says, fit a new engine. Loncin happens to be a favourite of mine.
    PS. When it cuts out, have you checked that there is still a spark ?? We may all be up the wrong tree!!
