Rebuilt Briggs starts and runs nicely.
Home › Forums › The Main Forum Area › General talk and discussion › Rebuilt Briggs starts and runs nicely.
  • #23669
    Feeling quite chuffed. The old B&S 3hp that was originally on my Wolseley Wizard has been rebuilt.
    The original pulsa-jet carb was used to get my water-pump going so, it needed a new carb.
    A complete motor with correct carb was obtained at the COEPS sale in November and the various parts purchased (gaskets, air-filter, piston rings etc.,) Valves were lapped in and gapped correctly and the whole lot put back together.
    Pleased to say, that it started 4th pull (about right for a pulsa-jet) and ran beautifully, no smoke, no rattles, no coughs and splutters. Carb needed very little alteration from the 1.1/2 turns. Only downside; the right angle bend in the exhaust kept vibrating loose so, I had to remove it and replace the exhaust on its own without a bend.
    I now have to find a use for it ! Two possibilities. 1) I have another Wizard minus its engine and 2) I have the tractor unit from a Howard 200 (also minus its engine) that could be turned into something useful. Both options have potential.
    #23686
    Well done, If I remember right you fitted a Chinese engine to your wizard. Has it been OK.
    #23705
    Hi Owen,
    Yes, It’s done about 20 hrs since fitting and has been excellent. Now it is properly run-in, it pulls like a steam train !
