Home › Forums › General › Help and information › Power Skip ID help!
- This topic has 10 replies, 3 voices, and was last updated 7 years, 5 months ago by
May 6, 2019 at 8:58 am #31124
vhgmcbuddyKeymasterMay 6, 2019 at 7:15 pm #31126
alanParticipantLooks interesting! To potentially narrow it down a bit, do you have any idea of the original colour or any id on the equipment?
May 6, 2019 at 7:58 pm #31127
vhgmcbuddyKeymasterHello Alan. I will have a scrape tomo and get a pic of the gearbox. Thanks.
May 7, 2019 at 6:29 am #31129
charlieKeymasterAnother photo showing a view from end with drawbar would help too.
May 7, 2019 at 8:08 pm #31133
vhgmcbuddyKeymasterMay 8, 2019 at 6:35 am #31137
charlieKeymasterP R Motors of Coventry were what remained of the Riley car company, the PR stands for Percy Riley.
May 8, 2019 at 6:48 am #31138
vhgmcbuddyKeymasterAh ha, well thanking you kindly, my first lead,👍😄.
May 8, 2019 at 7:04 am #31139
vhgmcbuddyKeymasterIt seems PR motors made a gearbox for dumpers in 1955 known as the cm, constant mesh. I will have a look inside this one as the older crash boxes are described as fabricated and cast steel. My one is a cast alloy, model not on the plate! It still seems to engage and drive with the diff working fine, a test would be under load. Next to find how it originally looked, the late 90 yr old owner who gave me it cannot remember, he towed it around behind a grey fergie! Cheers the noo.
May 8, 2019 at 9:16 am #31140
alanParticipantLooking through the archives it might be the remains of a Stothert & Pitt powered barrow. The one in the image has a Robin engine although S&P used Villiers MK12 and MK15 engines on many machines.
https://vhgmc.co.uk/wp-content/uploads/2019/05/Stothert-Pitt-Powered-Barrow-1.jpg
May 8, 2019 at 11:38 am #31143
vhgmcbuddyKeymasterThats great Alan, top marks I’d say. That makes sense now as it is too small to be a four wheeled dumper so its history is a drawbar being welded on after the engine died and other brackets gas axed off too.
So the plan now is to marry it to an auto gardener that is beyond repair to original and conjour up a 4wd Doe style twin engined oddity,👍😀.
I will keep you posted once every other project gets done, oh and paying jobs, 🙄. Thanks loads for your time, Andy King near Kinross.May 8, 2019 at 2:07 pm #31144
charlieKeymasterI only learnt of P R Motors through the work I have been doing as a volunteer at MERL cataloguing the Geo Monro drawings they have. P R Motors name appears on some of the drawings and it appears they carried out some machining and assembly work for Geo Monro during production of the Rototiler 56 and 35.
