Just acquired a 1965 Atco lawn mower with the Suffolk 75 G engine.
Was suspicious because it looked in remarkable condition due to being smothered in oil and dead grass.
However have had it to bits and cleaned everything up and checked that everything worked.
Sealed all the joints,decoked the engine and got it started and running really well,cuts grass like a new one, no oil leaks from joints, however a fine oil spray on my boots from the exhaust pipe suggests a problem.
I guess its the piston rings that must be worn, The bore was lovely and smooth and there didn’t appear to be any piston slap. So fingers crossed it only needs new rings.
Can anyone tell me what the tolerance gap of the rings in the bore is? There are no marks on the piston so I reckon it’s a standard original piston.
