Monrotiller spray pump
Home › Forums › The Main Forum Area › Projects › Monrotiller spray pump
  • #28816
    This is something I have had on the shelf for a few years and at last got around to dismantling it today.
    Has anyone seen one like it? To me it has a certain degree of home made look about it, although from memory it is similar to an Allen Scythe pump.
    I think I will need to replace most if not all the pipework. The pressure gauge will also need replacing and the spring in the pressure relief valve is broken.
    Very simple pump with ball bearings acting as valves.
    Allen Scythe pump
