Home › Forums › The Machinery Forums › Pedestrian operated machines › Monro tiller spark plug
I think I am going to change the condenser it was the only part of the ignition I didn’t change during the rebuild.
Whenever I rebuild a Villiers magneto I always change coil, points and condenser at the same time. That way I only have to set timing once rather than numerous times after changing one component at a time.
Hi the wire from the coil to the points isn’t long enough. Do have to use a specific wire or can I use a strand from normal three core cable?
Yes you can , I’ve done so many times before.
Ok thanks
Remember Me
