Lawnmower wheel
Home › Forums › General › Help and information › Lawnmower wheel
  • #31742
    brian-penfold
    I have a 7in cast iron lawnmower wheel that I dug up in a garden and I am trying to identify it, it has the name of “Guildford” in large letters on the outside of it but no other marking at all. looks like it is from a push mower as it has the grooves on the inside that a pinion gear would run on, any ideas?
    #31762
    Could be; if you could post a photograph it might help with identification.
    #31763
    brian-penfold
    As you say it does look like a mower wheel. Is Guildford the model or where it was made? It might be worth sending details and a photo to Alan for inclusion in The Cultivator.
    #31766
    Correct me if I’m wrong, but Dennis mowers are from Guildford. If it was Dennis then it would be more than likely from a gang mower – but surely Dennis would’ve put Dennis on there?
    It could be a casting for a more general machine that carried numerous retailers names. Then again I could be wrong!
    Any members near Guildford have any thoughts on this?
    #31767
    Dennis did come from Guildford and they did make a set of mini gangs that were known as Guildford gangs – as in Premier and Paragon cylinder mowers etc. That said, if it is from a gang I would expect it to have a rubber tyre. I think that you could well be correct in thinking that it is the remains of a small side-wheel push mower that was made for a specific retailer – as was the practice of the day.
    #31769
    brian-penfold
    Thanks everybody, I found the wheel under a Hydrangea bush where I was working it had been buried there to keep the flowers blue! I will try to the Cultivator to see if any other members have any ideas.
    #31785
    Drummond also came from Guildford. It is strange that the wheel only has Guildford cast into it, suggesting it is the model name rather the makers name.
    #31788
    brian-penfold
    There doesn’t seem to be any markings on the inside either, where you might expect to find a makers mark, bit of a mystery.
