Landmaster kestrel duplex chain required
Home Forums The Machinery Forums Pedestrian operated machines Landmaster kestrel duplex chain required
Viewing 1 post (of 1 total)
  • #14887
    Hi I own a Landmaster Kestral that i have finally got around to mechanically restoring, as i brought it as a barn find heap. Any way after un seizing the engine rebuilding the valve train, carburetor and the ignition system, i have it running like a clock. However i found to my disappointment that the duplex drive chain to the blades is broken! the split pin has failed.
    Does anyone on this forum know where i can find a replacement or know the sizes (pitch etc)so i can go off on the hunt for one. Im based in southern Ireland and bearing and chain specialists are few and far between.
