Morning all
I have just joined vhgmc….
I have owned a Gardenmaster 80 for 15 years, and always managed to keep it going (More easily after fitting a fuel filter to catch the rust from the tank!). It has a JAP engine.
This year I cant get a spark. Points in good nick, plug (although unlikely) changed, awaiting a condenser in the post. However, the LT winding (connected to the condenser) of the ignition coil/magneto shorts to earth. I imagine there should be several ohms resistance?
So could anyone help me, please, with:
– what should the resistance be?
– If necessary, where could I get a replacement coil/ is it possible to repair?
– Approximate static ignition timing and points gap (Flywheel has no key way)
– Is this a JAP 80 engine?
– Would someone be able to give me access to a manual/ parts list? (I would be fascinated to find out more about this machine, as I have been making it up as I go along!)
Many thanks in anticipation!
Guy
