Landmaster Gamecock rotary hoe
Home › Forums › The Main Forum Area › Projects › Landmaster Gamecock rotary hoe
  • #32114
    Hi all looking for a manual for this landmaster gamecock rotary hoe as under repair
    Depends what information you are looking for. The owners manual gives routine maintenance instructions and has an illustrated parts list.
    #32127
    Thank you Charlie i have this but need more details like work shop manual if still around have took apart the hoe end and found the bearing gone on shaft so looking to replace them and make some new hoes for it here is to photo all the bits cleaned and ready to put back together again got some welding to do on case and find brass bearing shells
    I have never seen a workshop manual for any of these smaller garden machines, Howard Gem is the only one that I have seen.
