J.A.P. engine valves? Howard Gem
Home › Forums › The Machinery Forums › Pedestrian operated machines › J.A.P. engine valves? Howard Gem
  • #36807
    Hi. I have a Howard Gem with JAP 600 side valve engine, for which I need new (or perhaps good used!) valves. They bear the number 7524. I have one one valve which could be used as a template. So, two questions!
    1. Do you know who might be able to supply such a valve, or modify a similar valve from a blank?
    2. Does anyone know the actual dimensions of this valve? – if one is to be made it would be better to know these rather than measure with vernier calipers.
    Thanks for your help.
    #36808
    ransomes256
    Have you tried MEETENS ?
