Home › Forums › The Machinery Forums › Pedestrian operated machines › Howard Rotovator transmission repair
- This topic has 11 replies, 5 voices, and was last updated 7 years, 10 months ago by
May 18, 2018 at 2:14 pm #28494
vhgmcbuddyMemberI’m tackling a new venue these days. I have a 1940s “The Gem” that has broken something in the transmission. My first queery is…. what is necessary to remove the right hand cover plate to view the damage? I already have the wheel off, and curious how much force should be needed to remove the wheel hub from the splines. Also, is in necessary to lay machine on it’s side to prevent scattered parts when I remove the side cover.
Thanks in advance for any help.
DanMay 19, 2018 at 7:10 am #28496
charlieKeymasterThe axle shaft is not splined but does have key in a keyway, it should come off using a hub puller. You can remove gearbox side cover without any parts falling out. Other members with more detailed knowledge will be able to give more information.
May 19, 2018 at 1:10 pm #28497
vhgmcbuddyMemberCharlie, thanks for the response. The wheel drive flange has what look like 8 approx 1/4″ splines in it that match to the same on the “shaft”. I see a much smaller dia piece inside of that too, but since the wheels turn independent of each other when in neutral, I thought perhaps they are driven individually as well. This brings me to my next question……what is the fastener type on these machines? Metric? Wentworth? or another? The wheel studs seem to measure just under 13mm and I believe 2.00 pitch. I need to determine this to get longer studs to use with a T-bar puller.
Cheers!
DanMay 19, 2018 at 3:15 pm #28498
roatavatorParticipantHi Dan
I used to have a Hatz Diesel Gem. Never did any major work to it, but there’s a manual here you may find useful if you haven’t already got it. Good luck!
Peterhttps://www.allotment-garden.org/rotavator-manuals/Howard-Gem-Service-Repair-Manual.pdf
May 20, 2018 at 1:58 am #28505
vhgmcbuddyMemberCharlie I owe you an apology. Finally got a few minutes to look closer at “the Machine”. What look like splines or keyways are merely rather evenly spaced flashing flaws from the casting process, Im guessing. Sorry about the confusion, but I am new to this type of old design and structure.
thanks again for your interest.
DanMay 20, 2018 at 2:10 am #28506
vhgmcbuddyMemberWow, thanks loads, Peter! Just getting started and only done some preliminary research for help books. This is great.
May 20, 2018 at 7:53 am #28508
roatavatorParticipantYou’re welcome Dan.
Always good to find manuals on the net for free!
PeterMay 21, 2018 at 2:22 pm #28521
vhgmcbuddyMemberSo…. Ive removed the side cover, and what did I find? Four balls missing out of the bearing at the starter crank end of the jacksahft. And some deep impressions in the bull gear idler gear. Ouch! These are some tough gears. Next step will be to remove the axle shaft assembly and see what’s behind it, lying on the bottom of the case.
Anyone know where best to go for gaskets and parts as needed?May 30, 2018 at 9:26 pm #28605
vhgmcbuddyMemberHi,if it’s any help I have 2 gems for spares,let me know what you need
May 31, 2018 at 8:44 am #28612ted20
Participantwhat part of the country are you located? I have a spare gearbox if you are stuck
June 6, 2018 at 1:44 pm #28627
vhgmcbuddyMemberSimon and Ted, thanks for the replies. Yes I will need some trans parts. I have emailed a chap in UK and waiting for his response to my actual parts search. I used his online parts catalog so I have the original part #s from that. I’m in the US, on the West coast so anyone stateside would be great.
DanJune 10, 2018 at 10:57 pm #28639
vhgmcbuddyMemberSimon,
It looks like Ill have to out-source the combo nut/pilot bearing for the rear flywheel on this Wisconsin. Any ideas?
Dan -
