Howard Gem Tyre size
Home Forums The Machinery Forums Pedestrian operated machines Howard Gem Tyre size
  • #26454
    Hello,
    I own a howard gem series 4 (G41663) and both tyres are rubbing on the body of both wheels; on the lhd side the tyre rubs on the “Jack Shaft Extension Casing” and on the rhd sideo the bolt at the bottom of the “Starting Handle Support Lug”
    I guess that the tyres are not the correct size for the machine and I cannot read any detail on the tyres.
    Can someone tell the correct size/type and where I can get them from?
    Many thanks in anticipation.
    Rob
    #26455
    hortiman
    Hi there Rob.
    The original tyres were Dunlop Grassland 4.00 x 12. but these are no longer available. some of the tyres with deep treads will foul on the machine, you can get some with shallow treads, I have used Trelleborg ones successfully, there may be others.
    Chris
    #26463
    hortiman
    Hello Rob.
    With ref to the last message – I mixed up the tyre manufacturers, it should be vredestein not Trelleborg who make the correct tyres.
    Chris
