Howard bantam
Home › Forums › The Main Forum Area › Projects › Howard bantam
  • #4722
    Hi all
    This is my first project I am starting its a howard bantam with a villiers 25c/24c engine (unsure at this moment in time)
    After a few hrs work I’ve removed the engine and striped it down as it only run for a few seconds then cut out (umm last owner said he had just had it serviced – let’s find out how good the service was carried out)
    So here’s where I’m at:
    Magneto removed (cleaned and polished 1/4 of the fan is missing)
    Pulley removed
    Barrel removed (honed and first coat of paint)
    Crank cases split (found a nightmare inside bronze seals and springs all in the wrong
    Places I’ve got to figure out which way the new ones will fit)
    Carb striped (cleaned, dry built up again ready for new gaskets, float and a needle as
    it’s a banana)
    Exhaust (cleaned and first coat of paint)
    So all in all I’d say Stevie wounder could of serviced it better
    All comments or advice are appreciated
    Jamie
    Some more pictures
    Sorry to here the deal was smothered in a pack of lies.well looks like your going to make a sucess of it from what we are seeing. Good luck.
