Hi I have a couple of rims with hex centres off of a f 400, I will check the size of the hex centres, when you say 10″ rims do you mean the outer diameter of the tyre, the tyres are cracked slightly but have new tubes in them and would be ok to use, I thought that they might be the same size on the F400 as on the F600. I will check the measurements and get back to.you Regards ct33731. Chris Taylor.
