Home › Forums › General › Help and information › Fuel leak help
- This topic has 11 replies, 3 voices, and was last updated 9 years, 1 month ago by
February 19, 2017 at 9:53 pm #24448
bish
ParticipantI’m trying to resolve a fuel leak on my Cultmate it’s coming from where the fuel pipe from the tank bolts onto the bottom of the carb. I’ve tried pinching it tight but it still floods out has anyone got any ideas on how to fix it?
February 20, 2017 at 9:37 am #24452
charlieKeymasterWhat carb is it? Does the banjo on the pipe have a fibre washer on both sides where it bolts to the carb? Have you tried new washers?
February 20, 2017 at 10:16 am #24454bish
ParticipantIt’s an Amal 124 I’ve changed the fibre washers between the bolts holding the bowl onto the carb body but it’s leaking from where the pipe bolts underneath the float bowl.
February 20, 2017 at 10:19 am #24455bish
ParticipantFebruary 20, 2017 at 10:46 am #24457ted20
Participanttwo possibilities one thread on union or carb stripped two fibre washer between pipe and float chamber Dave
February 20, 2017 at 10:52 am #24458ted20
Participantanother thought is petrol running down pipe or above connection if flowing between pipe and union cut off end of pipe and use brake pipe flaring tool to put new collar on pipe Dave
February 20, 2017 at 4:07 pm #24460
charlieKeymasterIt sounds as if the olive on the end of the pipe is worn or damaged, or the fitting in bottom of float bowl is damaged. Nut on pipe should pull olive on end of pipe up tight into the fitting on float bowl.
February 20, 2017 at 4:08 pm #24461
charlieKeymasterAnother possibilty is joint between pipe and olive is cracked.
February 24, 2017 at 9:03 pm #24512bish
ParticipantRight solved the one problem and caused another. There was a split in the pipe so swapped that for a new pipe which fixed that leak however I now have fuel flooding out of the top of the carburettor float chamber. It’s pouring out of the tickler hole and there’s two small holes on the side of the chamber cap which look like they are supposed to be there but fuel is squirting out these holes at quite a pace? Could the position of the float have anything to do with this problem?
February 24, 2017 at 9:14 pm #24513
charlieKeymasterIt could be float height or valve not closing on seat properly.
February 24, 2017 at 9:52 pm #24514bish
ParticipantThanks for your reply Charlie would you know what sort of height the float should be?
February 26, 2017 at 10:15 am #24515
charlieKeymasterI don’t have any information on the Amal 124 carb unfortunately. Valve on float should close before float chamber floods.
