Home › Forums › The Main Forum Area › General talk and discussion › Engine failure
I recently picked up a couple of machines, one was a SIMAR 5D. Somehow I do’t think this will be running again. If you look carefully you will see the remains of con rod have started to seperate the two halves of the crankcase.
That does look terminal.
It will take more than a bit of fettling to sort out that little problem!
What the failure analysis charts would class as a catastrophic failure !
Remember Me
