Brake band
Home Forums The Main Forum Area Projects Brake band
  • #11450
    Hi all
    After a bit of advise I’m restoring a winch to go on my Bristol 20. The brake band has rusted away any ideas if it’s just made from mild steel or a spring steel?
    Thanks Richard
    #11451
    I’m guessing just ordinary mild but hopefully someone will know for sure.
    #11452
    hillsider
    You pose an interesting question there, it all depends on the expected loads that would be applied. For instance is the winch intended to be used in anger or just for display purposes, If not spring steel then certainly a decent grade of steel would be needed not just flat black bar, bearing in mind that the band will need to be rolled into shape and drilled for end fixings and rivet holes.
    Have you by any chance checked to see if the original winch manufacturer is still around? Alternatively you could try talking to the company linked here.
    https://www.industrialfriction.com/brake-bands/
    #11454
    ransomes256
    Richard,
    The original bands were probably spring steel but these are likely to be expensive to source. I suggest using stainless steel as this will have minimal stretch under load and more than serviceable for show and light use.
    Neil
