ATCO 14 Inch 4 Stoke
Home › Forums › The Main Forum Area › Projects › ATCO 14 Inch 4 Stoke
  • #21060
    Hi
    Just started restoring my ATCO 4 stroke.
    Engine is removed from mower and virtually stripped.
    Just having trouble removing the kickstart gear and nut from end of crankshaft.
    Also other issue is removing the clutch sleeve which is stuck solid
    .Cheers
    Mark
    stuart
    The nut may be LH thread ???
    Get some heat on the red clutch part and with a decent 3 legged puller it should come of the shaft.Also use diesel (not WD40 as it just vapourizes with the heat) as a penetrating oil to help it of.
    #21066
    Same questions and more or less the same answers as on another forum!
    #21070
    Just an update,
    The kickstart part is now stripped and crankshaft removed the nut pulled off over the key way, not had a go at the clutch yet, will have to wait not til wednesday,
    yes I did post on the other forum as well.
    Cheers Mark
