Home › Forums › The Machinery Forums › Pedestrian operated machines › Allen scythe
- This topic has 17 replies, 6 voices, and was last updated 5 years, 11 months ago by
January 7, 2020 at 6:57 pm #33028
vhgmcbuddyKeymasterHi, I’ve just bought my first Allen scythe (and consequently just just joined the VHGMC!) I’m wondering about the age of the machine and particularly the engine type. The serial number stamped on the brass plate on the engine cover is 18787. From the googling I’ve done I’m guessing this probably makes it an early model, assuming the numbers were consecutive. I’m also guessing that, if the engine is original, then it might be an 11c but I don’t know how to tell. It’s certainly 2 stroke. Is there any particular feature which would help me identify it? Is there a list anywhere giving the Allen serial numbers and what years they were used?
At the moment all I’ve done is to spray all the nuts with WD40 but it’s going to need a full rebuild by the looks of it. I’m aiming to get it going by the time the grass in my orchard needs to be cut in July or August – I hope that’s plenty of time!
Any advice would be gratefully received. (I’ll post a “before” picture in due course)
January 8, 2020 at 8:16 am #33029ted20
ParticipantA picture would help as regards dating MERL at Reading has details of Allen Scythes on record
January 8, 2020 at 9:27 am #33031
charlieKeymasterWelcome to the forum, which is only part of the club, to be a full member you will need to pay either now or when free trial expires.
WD40 is not the best product for freeing rusted nuts and bolts, something like Plusgas is much better as it is a proper penetrating fluid.January 8, 2020 at 8:21 pm #33033andyfrost
ParticipantWelcome , if it’s an 11C it will have a cast alloy cowling , pressed steel then it’s a 25C.
January 9, 2020 at 10:58 am #33035
vhgmcbuddyKeymasterThanks for your replies. Here are some pictures. The cowling is alloy so I guess that confirms it as an 11c Andy. It’s nice to think it’s an early model but all the info I’ve seen has been for later models with the 25c engine. If anyone has seen any info on the 11c I’d be glad to know of it for example to confirm the timing setting.
It seems to be reasonably complete appart from the cover plate for the flywheel, which I’ll have to look out for. One of the dogs which puts pressure on the blade is broken and I guess I’ll need another one if I’m to get the adjustment of the blade right.
Thanks for the tip on plusgas Charlie, I’ll look out for some.
I’ve included s picture of the identification plate ted20 in the hope of getting it dated at some point.
Lots to do! Not making much progress currently as I put my back out getting the thing down from the back of the car! Blimey they’re heavy!
Thanks for the help.
Iain
January 9, 2020 at 11:13 am #33044
charlieKeymasterI am visiting MERL next week (to continue cataloguing Geo Monro drawings) and will have a look at Allen Scythe information to get a date.
January 9, 2020 at 1:02 pm #33045
vhgmcbuddyKeymasterThat’s great Charlie, thanks
January 9, 2020 at 3:02 pm #33047andyfrost
ParticipantDeffo an 11C, nice and original , still retains the proper carb and fuel pipe.
January 9, 2020 at 8:52 pm #33050
vhgmcbuddyKeymasterThanks Andy, still wondering about getting more info on it such as the timing setting and points gap, though I’m a long way from needing to do either!
I’ve seen copies of two manuals advertised. One for a T model and the other for a TS. I think the TS has the 25c engine, not sure about the T. Do you (or anyone else) know of a manual that revered to the 11c?
I’ve managed to source a couple of spare dogs for the blade so that one problem solved, once I manage to free up the adjusting screws, though I can drill out and re-tap if need be.
Cheers,
Iain
January 9, 2020 at 9:57 pm #33052
vhgmcbuddyKeymasterI found the attached wonderful leaflet from Allen. Amongst lots of other stuff it says that model numbers 1727 to 12000 denote a “Mk 2” machine,above 12000 are model T. Nothing specific about TS.
Cheers,
Iain
January 10, 2020 at 8:33 am #33053
vhgmcbuddyKeymasterOh dear, too big a document, I’ll have to see if I can make it smaller.
January 10, 2020 at 2:51 pm #33057andyfrost
ParticipantIan , I don’t think I can recall ever seeing a book on the 11C , the timing and points gap will be the same as the 24/25C.
January 17, 2020 at 4:45 pm #33080
charlieKeymaster18787 dates from 1946 according to records at MERL.
January 17, 2020 at 9:26 pm #33096
vhgmcbuddyKeymasterThat’s great Charlie, thanks ever so much!
Iain
January 28, 2020 at 9:40 pm #33140
vhgmcbuddyKeymasterMaking slow but steady progress with my restoration. Took the petrol tank off tonight, seems very robust though rusty. It still had some fuel in but it’s also got loads of gunky stuff in there which seems to be mainly rust. Anyone got any tricks for cleaning it out? The filler hole doesn’t give much access but there’s no other way in, I’m a but puzzled as to how I’ll ever get it clean.
Suggestions welcome!
Iain
