Home › Forums › The Main Forum Area › General talk and discussion › A change of diet,
- This topic has 7 replies, 4 voices, and was last updated 12 years, 4 months ago by
hillsider.
December 13, 2013 at 7:00 pm #4017
hillsiderParticipantDecember 14, 2013 at 6:19 am #4033
vhgmcbuddyMemberRay, like you say the Villiers carb is similar to one I saw last week. Do you have the deflector which normally fits on the end to stop sea water entering in a storm.
December 14, 2013 at 9:35 am #4036
hillsiderParticipantNo, this one is fitted with the plastic inlet that is screwed onto the carb body. The storm shield that you refer to s still available but not fitted the case of this engine.
Would you believe the engine on this beast was designed to run on a 10:1 fuel mix I guess smoke and oil pollution was not too high on the agenda back when these engines were designed, there are conversion kits available to bring the ratio down to 25:1 but not fitted to this engine as it will not get much use and the oily mix has done a great job of preserving it so why mess with a working formula.https://www.saving-old-seagulls.co.uk
Follow the link above to a site that is very helpful and shows a great deal of information about these lovely old machines
December 14, 2013 at 3:00 pm #4038
vhgmcbuddyMemberRay, just had a good look at the seagull site. Lots of info there ,and when I got to the section about Mr J Marsden I can now see more than one connection why you put this on. In my opinion with the man starting Villiers engines off,none of us would have what we have collected and cherished without him
December 14, 2013 at 5:00 pm #4040
hillsiderParticipantWell spotted John, I had not read that bit of the site until just now.
December 14, 2013 at 5:51 pm #4041
wristpinParticipantI had – you sent it to me!
The Villiers/Sunbeam/Seagull relationship just goes to show how things evolved but are now just taken at face value.December 14, 2013 at 5:58 pm #4042
vhgmcbuddyMemberThe quality back then, good looking outboard Ray. I recon you might have seen the link below, I liked the technical part.
December 14, 2013 at 8:28 pm #4043
hillsiderParticipantThe materials used were certainly better quality than some some of those in use today, this is the second Seagull that I have returned to good health this year.
It made a change from the normal diet of small engines, it was a long time since I had last worked on a Seagull, we used them at work many moons ago on work boats around the Port and of course they came into the workshop for repairs.
Back then you could go into the local Marine Chandlers shops here and get almost everything Seagull off the shelf that is no longer the case though. -
