Home › Forums › General › Help and information › Sachs d500w engine will not start
- This topic has 24 replies, 5 voices, and was last updated 10 years ago by
August 20, 2015 at 8:35 pm #14145
MemberIve had the cylinder head off and the diesel is injecting just before TDC, I think along the same lines as you guys, I think I will get the pump refurbished, I really would like to get it up and running again, hopefully before the cold weather gets here
August 20, 2015 at 8:40 pm #14146andyfrost
ParticipantGet back to us later when you’ve had the pump done.
August 20, 2015 at 8:45 pm #14147vhgmcbuddy
MemberI will, and thank’s for all the advice from you Guys, Ken
August 20, 2015 at 9:22 pm #14148stuart
ParticipantWhen it injects Ken is the fuel completely atomized ??.It should look like a cloud of very very fine mist when it injects.If all you get is large droplets of fuel from the nozzle then that will never ignite under compression and your FI pump needs a good overhaul.
The following is the only information I have for a Sachs 500 engine (as fitted to a Howard Gem) but I guess your model is the same.I hope this helps…..
Fuel injection 1764 psi (must not be below 1470 psi)
Injection commences 25 degrees BTDC
Oil should always be visible in the front compartment of the engine.
Always use the starting knob (RH side from the front of the engine)…..pulling the knob retards the injection and prevents kick-back when starting.
Let us know how you get on :):)August 21, 2015 at 7:49 pm #14150hortiman
ParticipantHi there.
You should be hearing a squeak from the injector as it delivers the fuel. I am sure that you realise that you need a really hefty swing on the starting handle to fire up the zunder fuse.
I do have a manual if it is of use to you I could get it copied for you.
I may have a new pump somewhere too.
ChrisAugust 21, 2015 at 8:15 pm #14151vhgmcbuddy
MemberHi Guys, when I swing on the engine I get a fine fog coming out of the starter fuse hole when the fuse holder is removed, I cannot hear anything apart from a deffinate click or knock sort of sound coming from the pump area. Hortiman I’m very interested in the copy of the manual also the pump if you still have it,please could you message me some information regarding price etc, many thanks Ken
August 21, 2015 at 8:39 pm #14152hillsider
ParticipantJust a word of warning – if you are tempted to test the fuel injector by connecting it to the injector pipe and cranking the engine with the injector facing away from the cylinder be sure to keep hands and arms etc well away from the injector nozzle. Atomised fuel will pass through your skin easily and cause severe problems.
Apologies if you are aready aware of this but rather you hear it twice than after an accident.
August 21, 2015 at 9:01 pm #14153vhgmcbuddy
Memberthankyou hillsider, warning taken onboard, thank you for the warning.
August 22, 2015 at 8:09 pm #14158hortiman
ParticipantHi there
I will search through my souvenirs and get back to you after the weekend.
Regards
ChrisAugust 23, 2015 at 10:07 pm #14160vhgmcbuddy
Memberthanks hortiman,looking forward to hearing from you. Ken
