Horse drawn plough wheel bearings
Home › Forums › The Machinery Forums › Pedestrian operated machines › Horse drawn plough wheel bearings
  • #28434
    Not sure this is the correct place. Bought a horse drawn ridger (Howard or Bedford) recently and am pressing parts back into service, There are wheels and axles on the beast but no bearings in place. Wheels have a tapered bore. My father in law suggested that there is no bearing and all runs loose, does anyone have any opinion / information?
    Jeremy
    #28439
    dave
    Probably cast iron wheels and mild steel stub axles therefor no
    lubrication was needed. If you had of oiled them the dirt and dust would have got
    in to the hub and would have turned into grinding paste.
    Let them run dry and rattle a bit.
    Dave.
    #28440
    Adding some images. I now have 2 opinions that there is no bearing, seems strange that the wheel bore is tapered, perhaps just to make the casting process easier.
    Dave
    Many thanks, perhaps the taper is for the dirt to get out. At least there is no turning to create new bearings.
    Jeremy
    #28454
    They might be wooden? Sometimes they use Lignum Vitae…
    #28463
    Thank you . I have started with some simple pins and see how they go.. Should have then working soon on a rotavator ridger system, if they do not behave will add some wooden blocks. Got some apple which would be hard enough I think.
    Jeremy
