“IF” you,re absolutely certain the timing is correct , as it has been mentioned previously , it is vital on Villiers twostrokes.
You have now got to investigate both the crankshaft seals , and cylinder bore/piston rings , unless it’s a very late 25c , the crank seals will be the gland bush type.
